02-12-2016 07:40
02-12-2016 07:40
Best Answer02-13-2016 06:44
02-13-2016 06:44
Hey there @FitGirl22! Welcome to the Fitbit family!
I recommend you placing your tracker into a bowl of dry rice for 24 hours this will extract any moisture that remains inside the device, after your tracker has been in rice for 24 hours, attempt to restart your tracker.
Hope it helps, let me know how it goes!
02-15-2016 05:45
02-15-2016 05:45
The watch has been in rice for 40 hours and still will not swipe. There is a crystalized pattern now behind the screen. I have been contacted by customer support via email and they are working with me on this. Thank you.
Best Answer02-16-2016 04:42
02-16-2016 04:42
@FitGirl22 It's great to hear that you've tried the troubleshooting steps, I'm sure that support will help you out :).
Let me know the outcome!
