10-12-2017 13:07 - last edited on 11-03-2017 09:15 by AlessFitbit
Help
My surge suddenly stop syncing! Everything is the same, same phone, same surge, same app... it just won't update. I have not dropped or damage the fitbit in any way. I already tried re-starting the fitbit, re-starting bluetooth (yes, the phone bt registers the surge link), tried re-installing the app and even tried to re-install the fitbit but here is where it won't work... cannot connect! Any suggestions?
T
Moderator edit: Title for clarity
10-13-2017 10:28
10-13-2017 10:28
I am having the exact same issue. Have tried to resync and now it won't connect at all.
10-13-2017 16:01
10-13-2017 16:01
I have had the exact same issue for the last 2 weeks and have tried everything: updated the app, reset my phone and Surge, powered off my phone and surge--nothing works!
10-13-2017 20:12
10-13-2017 20:12
I am having the same problem
10-14-2017 06:31
10-14-2017 06:31
Me too! Mine stopped syncing three days ago and I can’t get anything to make it start syncing again!
10-14-2017 15:31
10-14-2017 15:31
My Surge completely stopped syncing today. I’ve tried everything I can think of. Help!
10-14-2017 21:31
10-14-2017 21:31
10-16-2017 06:47
10-16-2017 06:47
This worked for me...
@StariZec wrote:
I had the same issue after not syncing for ~10 days because I was away from my laptop. You can try holding the left button and lower right button down together for 10 to 15 seconds. Your Surge should be turned off. Wait a few seconds and turn the Surge back on again. I was able to Sync after restarting.
10-16-2017 06:51
10-16-2017 06:51
My Surge has also stopped syncing and nothing works. What gives?
10-21-2017 18:25
10-21-2017 18:25
syncing I tried the hold left button and lower right button also and turning off for twenty seconds and waiting, and then turning back on and it worked but I also found out on my labtop or desktop I had to leave the toggle in it. to keep it synced don't know why but I did give it a try good luck
10-21-2017 18:26
10-21-2017 18:26
yes it also worked for me , but I also had to leave the toggle in on my desktop for it to stay synced, thanks
10-22-2017 10:18
10-22-2017 10:18
I totally agree. My husband also has the Surge so I left the room with my laptop and phone, closed the door, placed the doggle into the laptop, and then re-synced the device. Only then did it work. Make sure that you are away from potential competing devices when re-syncing.
10-22-2017 15:06
10-22-2017 15:06
I am having the same issue with my fitbit Surge. It won't sync to my phone it won't sync to my computer. I have turned Bluetooth on and off so many times I can no longer count. And it find it very odd that we all started having this issue right around the same time. If anyone has been able to get it to work, please let me know what else to do. Thanks so much.
10-22-2017 15:07
10-22-2017 15:07
Tried this and it didn't work either...
10-22-2017 19:39
10-22-2017 19:39
Seems that for nearly two weeks it syncs for a day, then stops syncing again. I go through the entire process that the FitBit customer service folks recommended -- tuning the fitbit on and off, taking it off-line then putting it back online, unlinking and relinking, turning bluetooth on and off, etc. etc. etc. I've spoken to them three times via phone, and I asked each time if others are having syncing issues. They keep saying no, that I'm the only one. Clearly, I'm not!
10-23-2017 06:52
10-23-2017 06:52
Yes, mine works for a few days with iPhone only---used to also link to my computer and iPad, but no longer. I have only had it for a few months and the past month has been nothing but frustration. I am wondering if perhaps Fitbit did not update to new operating system in iPhone and iPad although I have updated both of them and all show current. My conclusion is that I may have to return the product with many tears. Have long been a Fitbit happy customer but the Surge has "done me in!" Wonder if this is why it is no longer offered on their web site.
10-23-2017 07:21
10-23-2017 07:21
Makes me wonder whether anyone from Fitbit is actually reading these messages!!!! I suspect you may be right about them not updating their own operating system to work in conjunction with the new IOS system updates from Apple. Shame on them if that's the case -- and they're certainly not owning up to that situation when you talk to their customer service team on the phone. They make it sound like the issue is entirely your fault, and that you're the only person having that problem!!!
