08-04-2016 17:30
08-04-2016 17:30
Best Answer08-06-2016 05:03
08-06-2016 05:03
Hi @paf it is great to see you here again in the Community! As far as hiking goes, there are some features that you can use in order to obtain that information that you are looking for. If you want to get a map with the route that you have walked, you can use the multisport function which instantly starts GPS. After you sync your tracker you will automatically get the map. To track the elevation gain you can make use of the floors counter. Every 3 meters that you gain in elevation, will be counted as a floor.
I hope these tips help you and I also hope that you have a great weekend!
Best Answer08-06-2016 06:01
08-06-2016 06:01
