11-20-2017 07:19
11-20-2017 07:19
In cold weather, instead of walking outside, I often work out on my NordicTrak. When walking, I get about 1000 steps per 10 mins of walking, and I figure it should be about the same on the NordicTrak (using the Elliptical setting, since that is the closest I could find). That is sometimes the case, but at least half the time steps are underrecorded, only about 1/4 to 1/2 what they should be. Sometimes stopping the count and restarting fixes the problem, but not always. There is no difference in what I am doing on the NordicTrak. How can I get it to record steps accurately all the time? I think this may have to do with a recent upgrade, since this has been a problem only in the last few months.
Best Answer11-20-2017 10:34
11-20-2017 10:34
Not sure which Nordic track you are using.
But your stride is different so it will not be the same as walking outdoors
Wendy | CA | Moto G6 Android
Best Answer11-20-2017 12:04
11-20-2017 12:04
It is the original NordicTrak, purely mechanical. The real issue here is that it records steps inconsistently -- sometimes I get (say) 2,900 steps for 30 mins, other times 350. There is little if any difference in my speed.
