05-07-2016 17:05
05-07-2016 17:05
Best Answer05-07-2016 20:16
05-07-2016 20:16
Best Answer05-07-2016 21:18
05-07-2016 21:18
I also like both. I like the surge for the GPS. But the Baze is sleeker and not so klunky. If I had to pick it would be the Blaze.
Wendy | CA | Moto G6 Android
Best Answer05-08-2016 05:20 - edited 05-08-2016 05:22
I hate running with my phone so, if I want to log my runs using GPS and I have a Blaze, I'll have no choice but to run with my phone. With a Surge you just strap on the tracker, start it in Free Run mode, and away you go, no phone, no nuthin'.
As an additional benefit to the Surge is much greater accuracy; when I run with folks in my running club with Charge HR and Blaze trackers when in GPS mode; the Surge, while certainly not as accurate as the full-sized Garmin unit I have in my car, has about the same accuracy as my Garmin Forerunner 205.
Best Answer05-08-2016 07:01
05-08-2016 07:01
Best Answer05-08-2016 07:31
05-08-2016 07:31
I have also heard of the band issues with the Surge, that said, I'm now over one year, 6.5 million steps and over 1,500 miles of running, and my band is still completly serviceable.
05-08-2016 07:47
05-08-2016 07:47
Best Answer05-08-2016 14:56
05-08-2016 14:56
I'm guessing the Blaze doesn't have the physical room inside the case to house the GPS functionality.
Best Answer05-09-2016 09:49
05-09-2016 09:49
Best Answer05-15-2017 12:16
05-15-2017 12:16
I walk, not run. Wristband on my $250 surge lasted 16 months. Very disappointing that the band is not replaceable.
Best Answer05-15-2017 12:39
05-15-2017 12:39
@Elsey The band is replaceable, though not by FitBit. Aliexpress sell them. They can also be found on Amazon.com and eBay. Come with Torx screwdriver need for around $20. Plenty of videos on YouTube how to do it.
Best Answer05-15-2017 13:03
05-15-2017 13:03
Best Answer05-15-2017 15:20
05-15-2017 15:20
@Elsey If FitBit told you that then they were somewhat economical with the truth. But then, they'd rather sell you another FitBit....
The replacement bands you can buy cannot damage your Surge. Of course, you need to take care removing the old band as, if you go about it ham fisted, you certainly could damage your Surge. But many many people have done this with no issue whatsoever.
Do a search on YouTube, loads of videos showing you how to do it.
