04-18-2017 10:44
04-18-2017 10:44
I'm on my third charging cord for my Surge and none will charge my Surge! I'm getting so frustrated! It's only 2 yrs old and I'm ready to get something else? Any help?
Best Answer04-21-2017 14:30 - edited 04-21-2017 14:30
Hello @CH65!
In this case I'd like to ask you some questions. What happened to the previous charging cables? When did you start experiencing this situation? Do you have any friend's or relatives that have a Surge? If so, please try to also use their charging cable.
In the meantime, I recommend that you try the following:
Look forward to your reply! Let me know how it goes.
04-24-2017 09:30
04-24-2017 09:30
Best Answer04-24-2017 12:06
04-24-2017 12:06
You have really squeeze them. Mine took a lot longer than I thought it should and after the restart it said my battery was full. go figure
04-25-2017 12:12
04-25-2017 12:12
Hello @CH65 and @chayden976!
@chayden976 Thank you for chiming in to help!
@CH65 I'd like to take a quick look into the syncing situation. Are you getting any sort of error message? If so, what does it say? What mobile device are you trying to sync to?
04-26-2017 10:34
04-26-2017 10:34
It took 4 days of trying to sync and it finally synced to my IPhone. I had tried numerous times to power down the watch and it would not power down. It finally went to a slight fade and then after I took it out of my Bluetooth setting and tried again- which I have also had to do before and tried it before without success. It worked.
Best Answer04-27-2017 14:32
04-27-2017 14:32
Hello @CH65! Thanks for that update.
That is very interesting. I'd say that we keep an eye on the tracker's behavior for the next couple of days and see if it happens again. If it does, please let me know right away.
Let me know if you have any questions.
