07-19-2017
12:03
05:47
07-19-2017
12:03
05:47
Battery shows as full on app but when I unplug the surge it dies within minutes.Never had a device so irritating
07-19-2017 12:31
07-19-2017 12:31
Hi, @Jase72, the app will only know the state of charge at the last sync. How are you charging your Surge? A computer USB port will usually only deliver charge while the computer is awake. When plugged in, does it seem to be charging?
If you post more details, I am sure someone can help!
07-19-2017 12:49
07-19-2017 12:49
It's fully charged but dies within 30 seconds of unplugging.Was a birthday present So I'm pretty annoyed as we took the original fit bit back because it wouldn't charge at all the Alta and upgraded to this one.It can go back in the morning I'll have one last attempt and have a refund if any more trouble.Thanks for your reply
07-19-2017 14:31
07-19-2017 14:31
Please clean the contacts
http://help.fitbit.com/articles/en_US/Help_article/My-tracker-s-battery-isn-t-charging/?q=not+chargi...
Then Do a Restart
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
Also See this thread for charging best practices. If you are not charging it correctly you could be damaging the battery
https://community.fitbit.com/t5/Charge/Fitbit-charge-battery-problems/m-p/1323307#M53291
http://help.fitbit.com/articles/en_US/Help_article/1799
If it doesn't help Contact Support Or take it back and exchange it where ever you got it
http://help.fitbit.com/?cu=1
Wendy | CA | Moto G6 Android
07-19-2017 14:34
07-19-2017 14:34
Clean contacts it's brand new out of the box.As for the restart I tried and it wouldn't do that either so it's going back .One last chance and I'll change for a tom tom
07-20-2017 01:21
07-20-2017 01:21
After all the trouble and seeing all the other problems i.e. Straps etc I've decided on a refund and change to a Garmin forerunner 35 .They have fantastic reviews and none of the problems associated with the Fit Bit.Thank you for all your help though much appreciated
07-23-2017 05:00
07-23-2017 05:00
Restart doesn't help as the instructions are for the Charge.
07-23-2017 05:32
07-23-2017 05:32
07-23-2017 06:01
07-23-2017 06:01
Hi, @cmr287, if you click on this help article you can choose your device to select restart instructions.
