05-01-2016 07:51
05-01-2016 07:51
05-02-2016 08:14
05-02-2016 08:14
Welcome to the Fitbit Community @Natpal
! Strange let me say.. What steps did you try?
In the meantime, I'd recommend trying the following:
Let me know if this helps!
Best Answer05-02-2016 08:32
05-02-2016 08:32
No, it didnt work? The only way I can get it to sync is to manually go to settings on the surge then tap "bluetooth classic" then "pair". It looks like it shuts down, then when it comes back on it will sync with my iphone. For some reason it just won't stay there? I also noticed when I put it on "sync all day" it tells me to set up my bluetooth then when I press continue it goes no where and the sync all day slides back to the off postition? Hope that makes sense.
Best Answer05-02-2016 09:12
05-02-2016 09:12
Bluetooth classic pairing is only needed for music control- you do not need it to sync to the app. Mine finds the Surge in 2-3 seconds- quite fast really. Have you tried restarting the Surge?
Do the following:
This worked right away on a friend of mine and hope this works for you!
Best Answer05-02-2016 09:37
05-02-2016 09:37
Best Answer05-02-2016 09:54
05-02-2016 09:54
I'd recommend getting in touch with Customer Support directly my friend @Natpal. I'm pretty sure they will do a deeper investigation and see where the issue is coming from.
Don't forget to mention all the steps you've done so far to avoid getting the same ones.
Don't lose the hope yet my friend, you'll be in good hands!
Best Answer05-02-2016 12:06
05-02-2016 12:06
Best Answer05-02-2016 12:29
05-02-2016 12:29
Did you try contacting Customer Support? Welcome here my friend @SunsetRunner!
Best Answer05-07-2016 22:39
05-07-2016 22:39
Best Answer05-09-2016 07:11
05-09-2016 07:11
Hey my friend @Emamino88, I've replied you here
