10-29-2017 10:40
10-29-2017 10:40
Ever since this update, my Surge won't sync with the android app and I tried with windows and its the same thing. I have tried all of the troubleshooting that I found and its the same. When I unpair it in my bluetooth, it will say "pairing rejected by surge." Please fix!
11-04-2017 09:10
11-04-2017 09:10
Nice to see that you're digging into the Forums @ZJohn, let me give you a warm welcome to our Community.
Thanks for trying those steps! It's odd you're getting that message since it usually is showed when you're trying to connect directly from the Bluetooth of the phone instead of going to the Fitbit App and try connect it from there, please confirm if you're doing so.
I would like to know which Windows phone your using. Also, check the requirements to proper sync with mobile devices. After doing so, please try the next steps to finally setup your Surge one more time before we check with Support your options:
Hope this helps!
