@Surgeband @blutzman Welcome to our Community! Your tracker is covered under Fitbit's limited 1 year warranty and since it was outside this period Support wasn't able to offer a replacement. If you notice anything similar happening to your tracker don't wait nor hesitate to contact support to request assistance. Also now Fitbit has extended protection plans through SquareTrade with some newer trackers.
I'll be around!
Best AnswerMy brother has the same problem, his wristband just broke on his surge. It is just dumb not to have a replacement band. I have had a fitbit one for a very long time and it works like a champ!
I have been thinking of getting a more advanced model like the HR which I bought though i had to return the first one i got as it didn't hold a charge and the replacement had the same problem so I am back to the one. I would like to track my heart rate and my brother up until this point has been happy with his surge but now it is off my list if you can't replace the wristband, how shortsighted.
More than likely with check out an apple iwatch or garmin as they seem to be more customer centric. Have a good day.
This is my third replacement Surge in two years. Each time the same issue and each time they send me a new one. They don't want the broken ones back. So, that tells me they know there is a big issue wit the band. Now on this one they said, "the original product warranty is only for one year so we can't replace your watch it is out of warranty" This current one is 6 months old! They will give me a 25% off discount on a new product! Why would anyone buy another one when it doesn't even last a year! I have Garmin and Sunto products that are 3 years old and no problems.
The exact same thing happened to me. Each replacement watch had the same strap failure within a few months. With this third and apparently final watch, fitbit says its out of warranty but will give me a 25% coupon. Why are they still seling these if the straps fail after just a few months?
Best AnswerThey don't advertise the wristband being replaceable on the surge, but I assure you that you can get one on amazon for $15....There are even videos on YouTube that show you how to remove the 4 screws.....
