09-12-2018 11:16
09-12-2018 11:16
Starting this again as it said my last one was solved, which it isn’t.
The swipe on my surge isn’t working properly. You have to press down really hard while swiping about 20 times before it works. It then works properly until you leave it for a few mins then the same issue. Tried to restart it numerous times and it’s not worked. Tried everything I could find on these forums to remedy it and it seems my issue is quite unique. Please advise!
Best Answer09-12-2018 12:43
09-12-2018 12:43
Since restarting is the general fix, check that it is a sensitivity issue and not a capacitive issue Dan.
(The harder you press, the more your finger flattens that's whats's making it work, not the pressure)
I've had swipe issues when fingers are really dry, usually a winter issue, and have to use more surface.
If you see no change after tapping your finger to your tongue then contact customer service chat to see what options are available for a screen sensitivity issue.
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
09-12-2018 12:43
WmChapman | TX
Best Answer07-05-2019 14:42
07-05-2019 14:42
my swipe also does not work. I used to be able to get it to move if I swiped 10-15 times but now it does not move at all. Turning it on and off makes no difference at all. Suggestions?
