02-12-2016 08:26
02-12-2016 08:26
my surge was set up using my phone but I cant get it to sync on my windows 8 laptop. i have the dongle in but it wont sync on the website or the windows store app. how do I get it to sync to my laptop and my phone?
Best Answer02-12-2016 08:27 - edited 02-12-2016 08:28
Make sure your phone's bluetooth is OFF, and it should sync up with the Windows 10 app. That is the only reason my Surge has failed to sync - forgetting to disconnect it from my phone by turning bluetooth off (or vice versa).
Best Answer02-12-2016 08:56
02-12-2016 08:56
Hello @masterwho,
Welcome to the community!
If you are still running Windows 8, you can sync with the Fitbit App, but you'll still need to use the dongle and enable permissions on the base stattion. To do this:
Alternatively, you can install the Fitbit Connect software. All that said, the upgrade to Windows 10 is free. I would just upgrade to Windows 10 and use the updated Fitbit App. It can sync with just bluetooth 4.0 and you'll no longer need the dongle.
I hope this helps.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
