01-01-2018 10:44
01-01-2018 10:44
I just noticed now that my clock is incorrect...it's 9 minutes behind the correct time. I don't see where I can fix it.
01-01-2018 13:09
01-01-2018 13:09
Please check your Phone and computer to make sure the time is correct there.
If so then try this
On the computer: Go to the Dashboard and click on the gear and choose settings from the drop down. Scroll down to time zone Change it to s different one. Sync it. Go back in and change it to the correct one and sync again
Phone: Click on account upper top right looks like an envelope. Scroll down to advanced settings and do the same as above
Wendy | CA | Moto G6 Android
01-01-2018 13:09
01-01-2018 13:09
If so then try this
01-01-2018 18:46
01-01-2018 18:46
05-14-2020 12:35
05-14-2020 12:35
Mine is not in the wrong time zone, it's 11 minutes slow. It was only 5 minutes slow until I restarted it...
06-18-2020 11:39
06-18-2020 11:39
MIne is off by 1 hr. and 58 min. I had let it run down and when I charged it I realized the time was off. . I think it must have stopped when the battery "died" and I recharged it!
05-19-2023 11:29 - edited 05-19-2023 12:37
The ‘best answer’ and other responses didn’t work for me. Through trial and error, the following worked for me (iPhone iOS 16.5): on your iPhone Settings > General > Date & Time, make sure ‘Set Automatically’ is ON. Then re-sync your FitBit via its app.
