Try a reset on the surge by holding the left and bottom right buttons in together for around 15 seconds or until screen starts to fade. Wait 10 seconds after it turns off then turn it back on. Remove it from your account then add it as a new device. If that doesn't fix it contact support and explain what you have done!
