On the dashboard click on the gear and go to settings. Scroll down to time Zone and change it there.
It will need to sync before it takes place
Also might want to check out the manual it can be very helpful
http://help.fitbit.com/resource/manual_surge_en_US
Wendy | CA | Moto G6 Android
Welcome @Harrynlil, I hope you're enjoying the Forums! @WendyB That was a very good and quick response! I would like to add that you can find the Time Zone by going to the Fitbit App in your phone, under Account > Advance Settings. Or check your Fitbit.com Dashboard on a computer, log in into your Dashboard and see the Settings option. This is located in the upper right corner, it looks like a gear icon. ![]()
I would also try the restart on your Surge and for syncing instructions check the information in this master post!
Hope this helps, I'll be around! ![]()
