Hi recently bought fitbit surge says ive walked over 1000 steps and over 800 cals have been burnt and there is no way i have its my lazy day ive done 200 steps at most and as for 800 cals burnt while sleeping and letting puppy out twice seems extremely high
This is a pretty weird thing, you getting more steps than what you did. Did you drive that day? Driving can give you credit for some steps that you actually didn't do. Did you log any activity such as walking or running? Has this happened before? ![]()
In your Dashboard online you can get more information and details about your calories and steps, if you check the timeline of the day, you'll see at what time this is happened. ![]()
Hope this helps and let me know if you need more help! It's great to have you in the Community! ![]()
Okay then @pixiept! I'd suggest a restart for your Fitbit. Then follow the accuracy test for steps, so we can verify how is this working. ![]()
1. Put your Surge on your.
2. Walk 100 steps, making sure to count a step each time one of your feet hits the ground.
3. Pause, then check your tracker to see your step count.
If your tracker counted less than 100 steps or more than 100, please let us know and we'll see if we can investigate further. Sometimes, when you start walking you may notice that your steps may not update on your tracker right away. After about 10-15 continuous steps, you'll notice the steps catch up and start updating in real-time with each step you take.
It's important to confirm whether you wear the tracker on your dominant or non-dominant wrist, you can do so by going to your Fitbit App > Surge > Wristband placement. Since this is a wristband tracker your Fitbit might confuse the movements of your hand with steps, it shouldn't be a large amount of steps but there is a possibility that it happens.
I'll be around! ![]()
