Hello @Bob0431 are you holding on to the hand rails?
You might have noticed that ive moved tour post about the Surge with a treadmill, from the post about tge Charge 2 and audio stats while riding a bicycle.
Great help @Rich_Laue! 😉 Nice to see you here @Bob0431! Fitbit trackers have an accelerometer to track your movement. So, holding the hand rails may impact your step count. However, please double check if your placement settings are correct.
Tracker location helps orient the screen correctly in addition to adjusting the sensitivity of step detection. To change your settings, in the Fitbit app go to Account tab and choose your tracker at the top of the screen. Or in the Online Dashboard, go to Fitbit.com/settings/device.
I hope this helps, keep me posted! 😉
