08-22-2016 15:08
08-22-2016 15:08
Best Answer08-22-2016 15:16
08-22-2016 15:16
...plug in to wall or computer and continuously hold the left and bottom right buttons to reset since it won't power down untethered - should reset after you count to 30 but before you get to 50...
Sorry for the frustration; bluetooth updates are notoriuos for bad handshakes when your battery is low, always a good practice to have plugged in when updating. The "stuck screen" or "freeze" only happens in the middle of an aborted sync or firmware update with a depleted battery 😉
Let us know you are back on the road Jack.
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
08-22-2016 15:25
08-22-2016 15:25
08-22-2016 15:16
WmChapman | TX
08-22-2016 15:25
08-22-2016 15:25
Best Answer08-22-2016 15:26
08-22-2016 15:26
