I don't see where I can set a specific calorie goal on the Windows App. When I set up a food plan, it seems it only gives me the option of choosing the amount of weight I'd like to lose, and how rigidly I would like the plan to be. On the web interface, I can set a specific target calorie amount. Is this not possible on the Windows app? Thanks in advance.
Hello @SorenBlaque,
It's there. Just do this:
You should be able to set your calorie burned goals from here.
I hope this helps.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
