Hello!
Have had to replace my surge and the strap had broken. However, having a problem with installing the new surge.
It says it needs an update, however, when I click on the button on my menu to update it - the pink bar - which should initiate the installation of the update, nothing happens. I am unable to use the watch currently - it has the screen which indicates I should set up via fitbit/setup - however, that's what I have done!
Any advice on how I can update the software another way or bypass this?
EDIT: Fixed- but is there anyway to replace the band somehow of the broken one? The device is still great!
Thank you!
Thanks - appreciated!
Fitbit didn't replace mine - I bought a new one! Do you know the protocol for changing out an old one to get a new one due to the strap and the costs involved? Just have read several different stories on this forum - would by the Fitbit in the UK.
If your old Surge is less than 2 years old then it will still be covered by the warranty (it's 1 year outside the EU) - see www.fitbit.com/returns
If it is then I'd suggest contacting fitbit customer support to discuss a replacement via one of the options in this link:
