04-18-2017
18:53
12:21
YojanaFitbit
04-18-2017
18:53
12:21
YojanaFitbit
I do a 5 km exercise. If I have my Surge set for walk but I jog for about 3 minute spurts and then walk for a bit will my Surge record it proper, or should I set it up as a different exercise? I don't want to change from walk to run since I am trying to do this in a certain amount of time.
Moderator edit: Clarified subject.
Best Answer04-18-2017 21:04
04-18-2017 21:04
I would do it the way you already are.
Wendy | CA | Moto G6 Android
04-18-2017 21:04
04-18-2017 21:04
04-19-2017 12:19
04-19-2017 12:19
Hi @DwightC! Nice to see you around! ![]()
I understand where you coming from, I tend to do the same. In my experience, as @WendyB said, it's best if you don't change it, as you'll be pausing your activity. Once you've synced the information you can check the details and if you're using the GPS information, the distance and the steps will show correct.
You can give it a try and let us know how it is working for you! ![]()
