03-10-2016
04:47
06:13
03-10-2016
04:47
06:13
@Leekin Welcome to our Community! I would like to add that we suggest you only use UL certified charging bricks as these should provide the correct voltage. You can find an example from Amazon here.
Let me know how it goes!
06-02-2017
00:31
10:43
SolangeE
06-02-2017
00:31
10:43
SolangeE
I did a PRACTICE test with an USBport multimeter. So that's the results:
Charging device: Port idle/Fitbit Surge connected
USB Toshiba computer port: 5,19V/5,16V
USB Dell computer port: 5,19V/5,12V
APPLE 1A wall charger: 5,22V/5,22V
Garmin wall charger: 5,2V/5,19V
BQ 2A wall charger: 5,12V/5,06V
MI 10000mAh powerbank: 5,2V/5,14V
Internet router with USB port: 5,32V/Not tested
LG 5V 1,2A wall charger: 4,98V/5,00V
Uncertyfied China wall chargers idle (tracker was already fully charged so not tested while charging): 4,98V and 5,2V.
The current stays ALWAYS(!!!) stable at the level of 0,07A (NO MATTER WHICH DEVICE WE USE) for the whole period of charging and drops to zero in the last phase.
For people who do not understand what I wrote above I'll make it short and clear: IT IS BETTER TO CHARGE YOUR DEVICE WITH LG 1,2A or BQ 2A WALL CHARGER THAN WITH USB 2.0 (USB 2.0 should give ~0,5A) of Your computer. Chine stuff without LU certificate look also better that an UL Garmin charger that I got with my Forerunner110.
Best regards
Marcin
Moderator's edit: Format
