11-12-2016 01:50
11-12-2016 01:50
Best Answer11-12-2016 02:27
11-12-2016 02:27
How many steps?
Did you get up and go to he bathroom?
Are your arms moving while a sleep? That will add steps
Wendy | CA | Moto G6 Android
Best Answer11-12-2016 07:59
11-12-2016 07:59
Best Answer11-13-2016 06:18
11-13-2016 06:18
That will add steps. If its not a lot I would not worry about it.
If it is you can enter a driving record to remove them
https://help.fitbit.com/articles/en_US/Help_article/Can-I-delete-data
11-17-2016 11:30
11-17-2016 11:30
Hey there! Welcome to the Forums @craig33! ![]()
I noticed the awesome response from that you got, if this solved your questions in regards the extra steps that you're getting while sleeping, I encourage you to select this post as an Accepted Solution. Marking posts as solutions is a great way of thanking another community member while also highlighting their solution, so that it may be discovered more easily by other community member's facing the same questions or issues as you.
By the way, thank you @WendyB for your participation!
In case that you need more help, I'll be around! ![]()
Best Answer12-06-2017 14:32
12-06-2017 14:32
I love about in bed I go to the bathroom before I go to bed + my steps are about 24 when I move about in bed trying to get comfortable
12-08-2017 06:45
12-08-2017 06:45
Great to see you here in the Forums @craig33!
Your Fitbit settings records your sleep in either "sensitive" mode for extremely detailed sleep reporting or "normal" mode for a more basic idea of your sleep patterns. The sensitive setting will cause your tracker to record nearly all movements as time spent restless or awake, why don't you check that. ![]()
Hope this helps, I'll be around in case you need more help! ![]()
Best Answer12-09-2017 14:45
12-09-2017 14:45
What about android device
12-12-2017 11:44
12-12-2017 11:44
Thanks for getting back! Sorry I didn't explain that tiny detail for those types of phones, if you have a Android phone you need to follow the instructions to change that specific feature in your Fitbit Dashboard on the computer and sync your Fitbit later with your Android mobile device.
Let me know if you have more questions! ![]()
