I've noticed you are new around @Myalonak48, so let me give you a warm welcome to our Community. Thanks for jumping in @Andrew103!
When you connect your Fitbit Surge for the first time, your Fitbit take the time of the device you're using to sync. Every time that you sync your Surge the time will be updated, if not check the following tips to change it.
Hope this helps.
Hey @Myalonak48! It's great to hear that you're able to connect your Fitbit! So glad to know this instructions were of great help! You're a pretty clever 70 year old man! Thanks for follow all suggested steps. If you need anything else, I'll be around!
Happy holidays!
