06-12-2016 08:48
06-12-2016 08:48
Best Answer06-12-2016 09:38 - edited 06-12-2016 09:38
It will if the rode is bumpy. A lot of people use an App called DriveBit on there phone and it will get rid of them
Wendy | CA | Moto G6 Android
Best Answer06-13-2016 09:38
06-13-2016 09:38
It's nice to see you around @gcaponejr
! As my friend @WendyB said, I'd like to share with you what I do in order to get rid of those annoying driving 'steps'. I have downloaded the 'DriveBit' app to my phone and I've got to tell you it has worked wonders since it does all the hard work of having to manually negate those steps.
The best part is that it's free and the only thing you should do before starting to drive is linking it to your Fitbit accounts. You just open the app and tap Start and drive. When finished tap Stop/Cancel and it will automatically create a Driving Log negating steps and flights of stairs.
Hope that helps to you!
Best Answer08-02-2016 08:47
08-02-2016 08:47
