I haven't actually tried using the auto-detect feature yet. I usually start & stop the timer manually. I think the lowest time setting to detect is 10 minutes.
If you slow down or pause for just a moment during the detction period, the timer might be resetting itself.
08-02-2016
08:28
06:54
08-02-2016
08:28
06:54
Hey, @Fendude! It is weird that it is not recording every time. You could try to restart your tracker and give it another try! And like our friend, @mysterymeat, said If this doesn't work I suggest you to add the Elliptical to your "Exercise Shortcuts" and then use try to record it that way.
Let me know if it works! c:
