08-22-2016 06:04
08-22-2016 06:04
Lost my Fitbit One for good this time, I think but looking at other wrist models.
I've read before about the strap problems on the Surge and others. Seems Fitbit replaces them until the warranty runs out then your stuck. Seems this problem has been going on since the get go!
I may have to look elsewhere for another fitness tracker.
08-22-2016 07:19
08-22-2016 07:19
08-22-2016 11:52
08-22-2016 11:52
Even that tracker has a bunch of negative reviews on Amazon.
08-22-2016 19:17
08-22-2016 19:17
I think all devices have issues doesn't matter what brand. I have just read through 10 pages of the newest reviews and ther are 8 reviews with less than 3 stars out of 10 pages so maybe they have sorted some issues. I'm sure there are other trackers which may be better for you.
08-22-2016 19:34
08-22-2016 19:34
08-22-2016 19:51
08-22-2016 19:51
08-23-2016 05:16
08-23-2016 05:16
Yes, vivosmart HR but the more Amazon reviews I read the more I get disappointed! I had used my Fitbit One for sleep monitoring but I now read where the vivosmart HR was showing sleep in the middle of the day. I go to the bottom of the page on Amazon, select read all and select all the negative reviews.
Do yo have any issues with the vivoactive HR?
09-14-2016 07:56
09-14-2016 07:56
Hi @wptski @Redmoonstar!
@wptski If your concer is the wristband you could try checking our newer trackers the Charge 2, Flex 2, Alta and Blaze which all have interchangeable wristbands and range from $100 to $200 in price. You can check them all here.
@Redmoonstar Thanks for your input.
Let me know how it goes!
