Surge will not sync, the time zone is correct but at this moment: 1:33 AM, my Surge says 11:56 PM. My app shows no activity going back to August and I’m no longer getting weekly email reports. When I try to sync. the line slowly creeps from left to right and then reverts to “sync now”. Surge has been running 2-4 days on a charge.
It’s 11:00pm and it is saying it’s 2pm
And I can’t sync up with it and have tried switching off and on but won’t work.
My Surge will not return to Eastern time from Central time. It changed automatically after I initially crossed into Central from Eastern but did not and will not return to Eastern after I returned home. I have already updated my profile to Eastern time and followed the instructions to reset, but nothing has worked.
Best Answer@bachldrs it sounds like your tracker is not syncing. @Bencracknell this probably pertains to you also
One step not mention is to clear the Fitbit App's cache, could also clear the phones cache.
@stovac and @atefb21 if the time is still off after a sync.
Manually set your location to the wrong tomezone
Sync
Set location to the correct location or use phone location
Do one more sync.
