02-19-2017 06:06
02-19-2017 06:06
I updated my Surge on my Mac and by mistake hit the delete button on my sleep instead of the update button. I also keep my Surge updated on my Samsung and my Windows Tower. So I updated my phone and my tower but the sleep record was gone. Is there any magic trick to get my sleep record back.
02-20-2017 04:52 - edited 02-20-2017 04:58
How you doing @DwightC? Thanks for the details, it's good to know that you take care of the updates, that's important! About your inquiry, that's a good one, by the way! You can bring back your sleep data by entering a sleep log, using the Fitbit App. Tap on the Sleep tile > Tap on the (+) sign (in the upper right corner) > Add Sleep Log. ![]()
If you prefer to use the computer, log in into your Fitbit.com Dashboard. Once you're in your Fitbit Account, click on Log > Sleep > Create a new Sleep. As a friendly tip, remember to double check the date that you entering, to bring out the correct data! ![]()
This will do the trick, good luck! ![]()
