04-01-2017 08:20 - edited 04-01-2017 09:06
I plug my fitbit in when I go to bed to let it charge overnight. The past couple of weeks it starts vibrating around 1am and wakes me up. I had to put a towel under it so it would stop making a noise. The only problem is it starts counting steps. this morning it had 16,400 on the display before I put it on. I am also having issues with the battery, about 4 hours and it is dead. I have not change any settings and can not find anything that controls this. I also checked and have no alarms set.
04-02-2017 06:29
04-02-2017 06:29
Welcome to the forums!
Is a fan going on in the room? As it will add false steps.
For the battery
Please clean the contacts
http://help.fitbit.com/articles/en_US/Help_article/My-tracker-s-battery-isn-t-charging/?q=not+chargi...
Then Do a Restart
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
If it doesn't help Contact Support
http://help.fitbit.com/?cu=1
Hope to see you around the forums!
Wendy | CA | Moto G6 Android
04-03-2017 11:16
04-03-2017 11:16
Hi @keitho, welcome to the Forums! Hope you're doing well, and enjoying some healthy activities!
I noticed that @WendyB has offered a really some suggestions to help resolve your issue. If so, I invite you to mark this post as the solution. Marking posts as solutions is a great way of thanking another community member, while also highlighting their solution; so that it may be discovered more easily by other community member's facing the same questions or issues as you. You can read more about Accepted Solutions
If this didn't resolve your inquiry, please feel free to post back with your questions! I'll be around!
Have a great day!
04-03-2017 13:26
04-03-2017 13:26
well, that did not work. It is almost like there is an alarm set or something. I checked my fitbit and online and it says no alarms. I even checked my phone to make sure it was not something with that. I stopped plugging it in at night and let the battery run out and plug it in when I get up. Thank you, Keith
04-04-2017 10:45 - edited 04-07-2017 09:09
Hi @keitho! Thanks for getting back, and for trying those steps!
If you already restart it a couple of times and it is not working I'd suggest try to turn it off at night! You can use the option "Shut Down" in your Surge Settings. This is very odd, there is no explanation on why it starts vibrating all of the sudden; if it is not using alarms. You can also try to reconnect it in the Account to see if this helps. I've sent you a PM too, please take a look of it.
I'll be around!
