10-26-2016 15:41
10-26-2016 15:41
I've had my surge for less than 3 months. I've never submerged it or worn it in the shower. For the last week or so, it appears to have a fog of moisture under the screen. The moisture at first seemed to come and go, but now seems to be just staying there.
10-27-2016 00:39
10-27-2016 00:39
If it's affecting use of the Surge then you could contact customer support to see if they will replace it under warranty:
10-28-2016
05:27
04:38
10-28-2016
05:27
04:38
Welcome to the Community @901norma and @SteveH thanks for stopping by and the information provided. As our friend here is suggesting, please get in touch with our support team, I know they will be glad to help you out. For a faster response you can contact them via phone or chat.
Let me know how it goes. ![]()
Best Answer10-28-2016 07:32
10-28-2016 07:32
Thanks!
Best Answer10-28-2016 07:33
10-28-2016 07:33
Thanks for the response. I did contact customer support and they said to try putting it in dry rice for 24 hours and if that doesn't work they assured me they will help. I am going to try the rice this weekend.
Best Answer11-06-2016 13:29
11-06-2016 13:29
Best Answer05-08-2017 08:01
05-08-2017 08:01
So yesterday my trusted Surge finally decided it was worn out. Hundreds of trail miles, canoe trips, kayaking, and it never let me down. Yesterday, all I was doing was some outside yardwork, I look at my watch and the screen is all fogged up from behind. I guess the seals have given out. What a shame it didn't fail on some outdoor adventure where it would make a good story. Really, the only thing it was experiencing yesterday was heat, humidity and some sweat. The watch still works, the moisture is still there, and there's some little red/yellow light that comes on on the right side of the display...I assume to be a warning light? Due to the moisture inside, the touchscreen seems to be unreliable at the moment. I was hoping there was some updated model, as I've had this one for a couple years (I think), but that doesn't seem to be the case. Now I have to decide, repair or replace? If replace, with what?
