07-20-2017 15:06
07-20-2017 15:06
Hi:
I have a 2 year old Surge which I use all the time. It works quite well. I have never gotten it wet, and I do clean the sensor screen as suggested by Fitbit. Lately I have noted. "Brown" sludgy substance under the sensor screen. Has anyone else seen this? The watch is working fine currently so I am wondering if this is something to be concerned about. Thank you for your help.
07-20-2017 21:01
07-20-2017 21:01
Clean it
Wendy | CA | Moto G6 Android
07-23-2017 13:40
07-23-2017 13:40
There are several sensors in your tracker, the one mostlikely to get clogged is the altimeter, on the back of the tracker you will see a small hole.
As for a sensor with a screen, are you refferring to the face of tye Surge?
