05-06-2017 10:31
05-06-2017 10:31
Best Answer05-07-2017 00:57
05-07-2017 00:57
if the cable will charge your fitbit via a usb plug then the cable is ok, if not then a replacement is needed.
try another usb connection.
Not knowing what O/S you run on the pc, you could plug the fitbit and cable into pc (if cable ok) and go into settings and device manager to see if the fitbit shows up. If it does show up in device manager just right click and uninstall the fitbit.
hopefully when you re insert the usb charger cable te drivers will re install and the pc wil recognise the firbit
if it doesnt show up and the cable is ok then further investigation is required
05-07-2017 00:57
05-07-2017 00:57
05-07-2017 13:55
05-07-2017 13:55
same thing with me ,it still does the same thing after uninstall
but it charges
Best Answer05-11-2017 00:51
05-11-2017 00:51
you have uninstalled the drivers for the fitbit ?? but it still charges ?
after uninstalling drivers reboot both devices and see if it helps
Best Answer05-11-2017 09:54 - edited 05-11-2017 09:54
Hello, @campbellsoup, @heathgk! It is nice to see you.
I would suggest you to try a different USB port to confirm if its the charger that's not working.
@heathgk, thanks for your help. You are awesome.
Also if you have a friend that could lend you a charger, you could try it and let us know what happens.
See you around. ![]()
05-11-2017 10:10
05-11-2017 10:10
05-13-2017 06:47
05-13-2017 06:47
Hey, @abeany! Thanks for the updates. I'm so happy to hear that you are back on track now.
I hope to see you around a little more. Have you checked our cool Discussion boards? ![]()
