04-12-2019
10:46
06:17
04-12-2019
10:46
06:17
Hello and welcome to the forums @Fathiya
There is no replacement battery for the Surge. These devices are all in one - battery and tracker are one unit. You might want to do a search to see if there is a way to do it yourself. See this thread, especially the last post and you might find the answer. Let us know what happens.
Best AnswerAmazon sells a kit and as the video shows or is a simple process to change the battery. It is not much more in cosy than the shooting fees would be. Just don't lose the screws.
