08-15-2016 11:27
08-15-2016 11:27
have had my surge for 18 months. have always had problems syncing. Sometimes have to restart Surge and try again, other times just have to wait a few hours and it magically syncs. Contacted support and was told out of warranty and they cannot fix it, would I like to buy another one. Um NO I do not wish to spend another $250 on a product that cannot be fixed and is considered disposable after 18 months.
Also having problems with condensation from sweat in screen and screen not swiping
Best Answer08-15-2016 11:23
08-15-2016 11:23
have had my surge for 18 months. have always had a few issues with swiping between screens but now it does not swipe at all. Contacted support and was told out of warranty and they cannot fix it, would I like to buy another one. Um NO I do not wish to spend another $250 on a product that cannot be fixed and is considered disposable after 18 months.
Best Answer08-15-2016 12:19
08-15-2016 12:19
From the Fitbit article: I washed my tracker
Place your tracker into a bowl of dry rice for 24 hours. This will extract any moisture that remains inside the device.
After your tracker has been in rice for 24 hours, attempt to restart your tracker.
Optionally check out the Fitbit Article regarding not being able to sync the tracker.
https://help.fitbit.com/articles/en_US/Help_article/1866
Best Answer08-15-2016 12:40
08-15-2016 12:40
