03-14-2017 13:12
03-14-2017 13:12
Hi, ive got a fitbit surge that I got a few months ago. I set it up fine, now ive come to finally use it it wont go past the fitbit logo. have tried resetting numerous times but still no luck. any ideas would be greatly appreciated?? thanks
03-15-2017 09:30 - edited 03-18-2017 09:26
Nice to see that you're digging into the Forums @beechy116, let me give you a warm welcome to our Community. Thanks for the fantastic suggestion @WendyB! ![]()
Sorry about Surge! Thanks for the troubleshooting steps that you already tried! I'd suggest trying the restart a couple of more times, while the Surge is plugged in into the computer. Then try to connect it back to your Fitbit Account, some times you get better results connecting with the computer. Which device are you using?
Other users have reported better results when using a computer!
Hope this helps! ![]()
Best Answer03-14-2017 15:15
03-14-2017 15:15
Welcome to the forums.
Was it set up once before and then put away? As not charging can ruin the battery
You can contact support and see what options they have for you
Hope to see you around the forums!
Wendy | CA | Moto G6 Android
