Hey there @MickKirby! It's great to see you in the Forums. Thanks for details of the error that you're getting. I would appreciate if you try the following steps to make your Fitbit Surge update properly. It's best if you try with a computer using this program, since your Fitbit is having a hard time connecting:
If this doesn't help, please get in touch with our Support group, so they can check this issue with you.
Hope this helps! ![]()
