http://www.myfitnesspal.com/topics/show/1134147-fitbit-sync-problem?page=13#posts-19121393
As of today 3/10/14 MFP and fitbit appear to be not communicating at all. Foods are not migrating to fitbit and calorie adjustments are not migrating to MFP.
I can't get my Fitbit to sync with MFP either. This has become an issue for me in the past week or so. However, normally when I have this problem, it was the Fitbit data not syncing to MFP, while the MFP data was syncing to Fitbit. Usually disconnecting and reconnecting the accounts would make it work.
Today, it's not syncing in either direction, and no amount of disconnecting and reconnecting seems to be helping.
Ugh. Frustrating.
I have the same problem, and the same problem last week. The syncing issues with Fitbit and My Fitness Pal are getting to be a regular thing every week.
Mine is not syncing either, Does the app/creator know it is not syncing?
@SabineS wrote:http://www.myfitnesspal.com/topics/show/1134147-fitbit-sync-problem?page=13#posts-19121393
Best AnswerI'm having the same issue. I've added and removed an exercise to MFP (as suggested on their help forums), and disconnected and then reconnected the apps. Nothing is working, and they're not syncing either way. The most frustrating part is that neither company seems to be replying with any sort of fix or update.
Best AnswerDitto, here! I've noticed this afternoon that the calories for additional foods I have entered in my snacks in MFP have not synced with my fitbit dashboard. According to my fitbit dashboard, I still have 352 calories I can eat today. That would be sweet if I didn't know it wasn't accurate!!
@Matthew wrote:We are aware of syncing problems with MFP, and are investigating the cause. You have my apology for the inconvenience, and we will post more information here as soon as we have an expectation of resolution.
Thanks Matthew. Your acknoweldgement of the issue is a help.
It does appear that MyFitnessPal was able to locate and correct the syncing problem, per their post here:
It sounds like the issue should be resolved, and syncing should resume very soon if it has not already done so. Thanks to everyone for their patience with this!
