02-01-2015
08:59
05:57
AngelaMa
02-01-2015
08:59
05:57
AngelaMa
Just a tip...
I found out that we can designate Flex as our device on the Walgreens Balance Rewards app even as Charge users. Charge isn't one of the device options yet. If you choose Flex even though you have a Charge, the steps log each day and you get the points toward discount coupons.
02-03-2015 15:51
02-03-2015 15:51
@GarudaGirl It's great to have you! Thank you for the advice, I moved your post to the Third-Party Integrations thread so more people can see it.
Best Answer08-02-2015 10:38
08-02-2015 10:38
This is helpful. How do I connect the Walgreens acct with my Fitbit Charge?
Best Answer08-03-2015 13:05
08-03-2015 13:05
@SunsetRunner A warm welcome to the Community! Please go here > Devices > Choose Flex (Even though you don't have) > click on Connect.
Keep me posted.
Best Answer09-13-2015 06:35
09-13-2015 06:35
Thank you Garudagirl. I just activated my Walgreen account and was disappointed I didn't see the Charge on there. This community forum is great when I have a question like that. Thanks for letting us know we can sign up as a flex and still get the points.
09-14-2015 10:47
09-14-2015 10:47
@CarrieV It's great to have you here! I'm glad to hear that @GarudaGirl's post helped you with your question.
Don't hesitate to share your knowledge with the Community or you may want to visit the Discussions Board and meet new people or find a good recipe.
Best Answer12-07-2015 01:42
12-07-2015 01:42
Best Answer12-07-2015 06:49
12-07-2015 06:49
@Dwluvspool Welcome to the Community! I love your profile picture
. Yes, your Fitbit account can be linked to Walgreens app. You'll get 20 points for every mile you walk or run, 20 points for recording a daily weigh-in and 250 bonus points when you connect your Walgreens account with Fitbit.
You can follow this procedure to link Fitbit with Walgreens:
- Go to the Walgreen page https://www.walgreens.com/steps/appmarket.jsp "Health Apps & Devices"
- Browse by category > Fitness & Sleep > Devices
- You'll see Flex click on Get it > below that you'll see " Connect" > click there and log into your Fitbit account
Note: Even though you click on Fitbit Flex to connect your Fitbit app it will work because it's just the tracker showing that you're connecting to Fitbit. However, this doesn't mean you're linking Walgreens to a Flex tracker.
Hope this helps.
Best Answer01-25-2016 10:36
01-25-2016 10:36
Hello SilviaFitbit! Thank your for your detailed steps on how to add a Charge to the Walgreens Balance Rewards acount. I've followed your instructions up until the last part. For whatever reason, the "Connect" button is greyed out and disabled. I figured it might be a fluke or the Walgreens site may be temporarily unavailable, but I've tried on numerous occasions at various times of day for almost two weeks now without success. Any tips? Thanks in advance!
01-26-2016 05:42
01-26-2016 05:42
@Ms.Aimee A warm welcome to the Community! That's pretty weird. As you can see Walgreens is in the list of supported apps here. So, it should sync properly. I would contact Walgreens to see if there's any issue with it.
Hope this helps. Let me know how it goes.
Best Answer03-16-2016 06:45
03-16-2016 06:45
Hi..This is great.. It works.
Thank you
Best Answer06-29-2016 15:28
06-29-2016 15:28
I noticed that if I try to add my charge to the weight loss page that it's greyed out. Check to make sure you're on the exercise page! Hope this helps!
Best Answer06-30-2016 11:46
06-30-2016 11:46
@ChaysPR Welcome to the Fitbit Community! I'm glad this worked for you.
@jbecker17 Hey there! Thanks for sharing those tips
Best Answer07-30-2018 10:31
07-30-2018 10:31
This is an old topic, but I just discovered the Walgreens app and the rewards program. Was confused when my device, the charge 2 wasn't listed. But thanks to this topic, I figured ito you can pick "flex" and then the Fitbit app will work with the Walgreens app.
