04-06-2016 20:40
04-06-2016 20:40
Fitbit Alta is not on list of accepted Fitbit devices for Walgreens Balance rewards. Can you please inform Wagreens Balance Rewards to list device for registration for healthy choices (approved devices). Other Fitbit devices are there but not the Alta.
Best Answer04-08-2016 16:36
04-08-2016 16:36
@SunsetRunner, you're probably better off contacting Walgreen's support yourself. I don't believe that Fitbit works with any of these companies on compatibility, rather, the other way around. Also, it may already be compatible and just not listed.
MakMak | Community Council
04-08-2016 18:15
04-08-2016 18:15
Don't worry about, just pick a tracker to connect, Fitbit will then tell Walgreens the tracker you have.
Walgreens does not connect to your tracker anyway, it connects to your Fitbit account.
So just pick a tracker listed, it all goes to the same place.
