Bought the Waterlogged premium app specifically because it integrates with Fitbit. I connected to Fitbit from the Waterlogged app and logged all my water intake in their app for 2 days, but water intake in my Fitbit app still shows zero. Anyone have a fix for this?
I reached out to @waterloggedapp on Twitter and I did get an initial response but it wasn't helpful. Still waiting for further response.
Hello @RBsoccermom, welcome aboard to the Fitbit Community! I'm wasn't familiar with Waterlogged since is an app I do not use. After I've read your post I gave it a try with the intention to replicate the issue you are experiencing.
I can see this integration send your water logs to your Fitbit account, so I logged 17oz. and after refresh my Fitbit account by pulling down the screen, my water entries were updated with 500ml. So my recommendation here is the following:
- Go to your online Dashboard and access to your Application settings.
- Here looked for the Waterlogged integration and click "Revoke Access".
- Make sure to force quit the waterlogged app (To do this might depend of the device you are using).
- Access again to your WL app and reconnect the integration with your Fitbit account and give it another shot.
Usually when an integration is failing the best to do is to revoke the access and re-connect the integration.
Hope this helps. See you around!
