03-12-2018
13:59
05:15
RobertoME
03-12-2018
13:59
05:15
RobertoME
Hi All,
just a quick one to find out what everyone is doing with their Fitbit and Mywellness account. Is It best practice to just let the fitbit track activities or is it better to log into the technogym machines with the mywellness account.
Just trying to figure out if activities are tracked twice if using the fitbit tracker and logging into the technogym machines at the same time or is the fitbit app clever enough to figure out it was at the same time etc?
Using a Charge 2 HR btw.
Thanks
Paul
Moderator Edit: Updated Subject For Clarity.
Hello there @PaulReyn10, welcome aboard to the Fitbit Community. This is a great question that I would like to hear what are the best practices of other Wellness users.
As far as I know, according to the integration MyWellness will have access to the following data from your Fitbit account:
Since this integration is not among our official apps, the information we have available is very limited regarding how far MyWellness goes to retrieve data from your account. Although based on what I know for other integrations; my recommendation is to use your tracker to read your exercise due to the heart rate data. Keep in mind that third party integrations doesn't have access to this information, which may caused variations on your calories burned. However it is important to consider what type of activity you are doing as this will have an impact on how your tracker is recording your information.
See you later and I will be around eager to see the development of this topic.
Best AnswerI use Charge HR 2 and also use Sunnto Quest with Ant + to talk to Wellness app and techno gym machines in real time. I can confirm that the exercises are not tracked twic. Also since I use both looks funny one watch in each arm that Surge 2 is nearly identical to heart rate monitor. Good job getting this close as HR monitors will always be more accurate
Best Answerquick question though - can I import data regarding activities from mywellness into the fitbit App? It seems it only works the other way ?
Best AnswerI have the exact same question..! But as Mywellness is not on the list of the Fitbit compatible apps, I’m afraid it doesn’t work that way unfortunately 😞. Mywellness collects the Fitbit data but not the reverse. As I prefer my Fitbit dashboard, I’ve had to disconnect the 2 apps. My charge 3 only detects my runs and nothing else ... so I have to make some maths to find out how many active minutes and calories I’ve burnt (minus the run) and enter them manually into the Fitbit app. I think it isn’t the most accurate way of doing things but I don’t know any other way... Any pieces of advice ? I just wish Fitbit and Mywellness (technogym) worked together in both ways....
It's now Jan 2022 and I have a Fitbit Versa 2 - I've joined the gym which has Mywellness machines. Still no idea how the two integrate other than my Fitbit reading my heart rate and steps!
Wonder if anyone can shed any light on this?
