06-13-2017 05:57
06-13-2017 05:57
I synced my Blaze with Strava on Saturday and was impressed with how it transferred activity, even runs I had recorded with Blaze before the sync were showing which was an unexpected bonus! Last night I ran, tracking with Blaze and nothing is showing on Strava, I have tried revoking and re-authorising but still nothing?!
Best Answer06-13-2017 06:44
06-13-2017 06:44
Fitbit servers are sending the data to Strava, so its either:
- an issue with Fitbit servers
- run/ride doesn't include GPS data (Fitbit only allows exporting GPS activities)
- bad data in Fitbit workout file, and Strava rejected it
I have a Garmin bike computer, and Garmin servers send my rides to Strava. Over 500 rides have been sync'd to Strava, and only 1 did not sync. I tried manually uploading to Strava via a web browser, and discovered the ride data was corrupt (near end of ride the timestamps jumped 22 hours ahead of actual time). The Strava upload interface was helpful - it offered a suggestion on how to fix the TCX file - and after fixing the file uploaded.
You might want to try downloading the TCX, see the "Exporting GPS Data" section of this article:
http://help.fitbit.com/articles/en_US/Help_article/1133/
And then try uploading to Strava by following the "Uploading a file from your computer" instructions in this article:
https://support.strava.com/hc/en-us/articles/223297187-How-to-get-your-Activities-to-Strava#byfile
Best Answer06-13-2017 06:00
06-13-2017 06:00
My run from earlier didn't sync with Strava yet either. I'm thinking it's an issue with Strava's server? That has happened before to me.
06-13-2017 06:44
Best Answer06-13-2017 08:01
06-13-2017 08:01
Thanks!
The manual upload sounded a fuss but was actually really straight-forward and has worked! While it's a little annoying that it didn't sync itself, hopefully it's just bad luck and it's useful to know there's a straightforward back-up plan!
Really appreciate the quick and helpful response!
Best Answer06-13-2017 08:10
06-13-2017 08:10
@Lyndsey-G glad that worked, and likely a temporary issue with Fitbit servers not sending to Strava.
