01-20-2017 12:11
01-20-2017 12:11
My FitBit account is idle since 2015 FitBit device lost in the locker room. Recent purchase of Garmin 920XT syncs with Garmin Connect application in my PC Windows10 and my Nokia Lumia Windowsphone10.
How can I share my data with FitBit friends so we encourage eachother?
Stephen
01-24-2017 06:00
01-24-2017 06:00
Hello @stephenrmills, good to see you again. In the past there was an integration between Fitbit and Garmin, however this third party association is not longer supported.
Perhaps is of your interest to vote for this idea on our Suggestion board about Garmin Connect Integration, because those suggestions are viewed by our engineers and developers. Our product team looks forward to reading and incorporating your suggestions into future versions of Fitbit trackers and apps. Although is worth to mention this integrations are not initiative of Fitbit, but from third party services who decide to integrate their services with Fitbit using our open API.
Hope this information helps. see you around!
05-30-2017 00:33
05-30-2017 00:33
For detailed steps of sharing data from Garmin connect use Garmin 920xt Manual . Here i am sharing basic idea of this setup:
Open the Connect Mobile application.
Android - Touch the menu icon (3 horizontal lines in upper left corner)
iOS – Touch the ‘More’ icon (bottom right)
Touch "Activity Stats" .
Touch "All Activities".
Select the desired activity.
Touch the menu icon in upper right corner.
Select Share.
Choose how you would like to share the activity, e.g, email, Facebook, and Messaging.
Share your activity by sending or posting the activity link.
Best Answer05-30-2017 06:36
05-30-2017 06:36
So if I use Garmin, but sync all activities to Strava.
Would I be able to just sync Strava with FitBit and have the records in FItBit?
I had no success with syncing Strava data to FitBit
Best Answer06-13-2017 05:00
06-13-2017 05:00
Hello @alkayahnik, thank you for sharing this information, I'm wondering which apps are compatible to received data by following this process?
Thank you for visiting us one more time @YuliyaL. Yes, you can integrate your Fitbit account with Strava, however as I mentioned in my previous post, the integrations may work different, so it's important to mention the following:
How you can integrate your accounts? Is easy: Go to https://strava.fitbit.com/ and click "Connect" and follow the rest of the prompts to finish reconnecting your Fitbit and Strava accounts
Hope this helps and see you until the next time!
