06-30-2021 16:18
06-30-2021 16:18
I just upgraded from Charge 2 to Charge 4. But my new Charge 4 won’t sync with my Arboleaf Smart Scale. The scale is syncing with my iHealth app but won’t sync with Fitbit app. All read/write permissions are turned on. Any suggestions??
Best Answer06-30-2021 17:40
06-30-2021 17:40
Hi @Leacjuneb14,
I would reach out to Arboleaf, as the syncing of the scale has nothing to do with your device.
As far as the Fitbit app, the best suggestion I have at the moment is clearing the cache on your phone or uninstalling and reinstalling the Fitbit app.
one cruise ship at a time!06-30-2021 17:40
06-30-2021 17:40
Hi @Leacjuneb14,
one cruise ship at a time!06-30-2021 18:07 - edited 06-30-2021 18:09
I have a different smart scale that I successfully set up, and linked to my FitBit app a week ago.
Tomorrow morning is my next scheduled time to use it, so I'll report back to let you know if it's a broader issue, than just yours.
My guess is that it's an issue on FitBit's side, since they've had general syncing issues from their end for the past couple weeks, and they'll fix it soon.
At least tomorrow morning you'll know if I suddenly have the same problem.
Best Answer07-01-2021 12:53
07-01-2021 12:53
Just checked my weight, and body fat percentage on my Renpho smart scale, and it synced right away with no issues to my FitBit account dashboard, and its weight section:
https://www.fitbit.com/weight
It also updated my FitBit app weight section, but that took a few minutes to show up.
Best Answer07-01-2021 17:52
07-01-2021 17:52
Thank you both for your replies. After reading your replies, I’m hoping I posed my question correctly. When I weigh myself on my Arboleaf scale, the measurements will show up in my Apple iHealth app (after a bit of time). But they never show up in my Fitbit app. I feel like the issue is with the Fitbit app, not arboleaf. Thinking trying a different scale (that has all these metrics. Im frustrated!
Best Answer12-03-2021 05:59
12-03-2021 05:59
I had the same problem. I see I'm late tot he game on this issue but I made one change to my FitBit app settings and checked on the Media and Apple Music slider. I looked at the FitBit app and it had updated my daily weigh-ins since I started using the Arboleaf scale. I hope this is the actual answer and helps someone else.
12-04-2021 08:46
12-04-2021 08:46
Please remember that the syncing of a non-fitbit scale is not handled by fitbit.
If you are having sync issues.
04-14-2022 14:08
04-14-2022 14:08
Where is that setting in FitBit?
04-14-2022 14:21
04-14-2022 14:21
In the Arboleaf app, click My Account at bottom-right, then Settings at top-right, then FitBit in the middle, and slide that slider off and back on. Another faster fix is to close the apps on your phone and reopen them, as I have found out later. On iPhone, double click your home button (I still use an iPhone 😎 and swipe the apps up to close out of them. Reopen them and see your weigh-ins populate in the FitBit app. I need to do the same thing in order to re-sync my MyFitnessPal app with FitBit and vice versa.
