09-11-2019 17:34 - last edited on 09-11-2019 20:08 by LiliyaFitbit
Im unable to sync with MyFitnessPal I don't understand why, I used to be able. Help!!!
Best Answer09-11-2019 20:07
09-11-2019 20:07
Welcome to the Fitbit Community, @Msdeai.
I appreciate your participation in the Forums and sharing that your Fitbit and MyFitnessPal accounts aren't syncing. I recommend doing the following:
1. Please confirm that your Fitbit device is syncing.
2. Revoke access to the integration with MyFitnessPal:
3. You can then re-link the two accounts by going to http://www.fitbit.com/apps/myfitnesspal. For more information, please see How do I connect my Fitbit account with another app?
After relinking, you can verify that your accounts are syncing by using one of the following data points:
1. On Fitbit you can check for your meal summary and logged activities from MyFitnessPal.
2. On MyFitnessPal, go to "My Home," then "Check-In." You should see your weight, Fitbit Steps, and Fitbit Sleep Minutes.
Let me know how it goes.
Best Answer09-17-2019 04:06
09-17-2019 04:06
I've tried this but when I click MFP on the works with page there is no option to link the two accounts.
Best Answer09-18-2019 17:41
09-18-2019 17:41
Welcome to the Fitbit Community, @SunsetRunner.
Thank you for joining the thread and sharing the difficulty you're experiencing with connecting MyFitnessPal and Fitbit accounts. Please confirm if you've tried the following:
1. Log in to your MyFitnessPal account.
2. Find the section for connecting another account. This section is often called "Apps" or "Connect."
3. Follow the on-screen instructions and log in to your Fitbit account when prompted.
