04-11-2017 01:17 - edited 04-11-2017 01:49
Hi All,
I have a charge 2. I recently updated the android app to the latest but haven't been given the option to update to the latest firmware (I understand it will roll out in waves). The new app is great, the addition of community tab and also the sleep stages are awesome and so accurate (to my perception).
I do have a problem though. I am using myfitnesspal to record calories since their food database is so much bigger, and the calories come through to fitbit android app fine like they used to. It is just that with the new app version (unless I haven't noticed before) a "MACRONUTRIENTS" header was added under the calorie section of the dashboard with a pie chart where it is supposed to display carbs, fat and protein percentages of what you ate so far. This doesn't get populated in the fitbit android app but it does show (grams and percentages breakdown) in the web dashboard.
Anyone that is facing the same issue or any solution to the problem out there?
Regards
Apostolos
04-12-2017 14:35
04-12-2017 14:35
I have the same problem, nothing shows up the app 😞
06-04-2017 04:29
06-04-2017 04:29
It happens to me, too. At first, I thought maybe that was normal, but if it appears on the web dashboard, it should in the app, as well 😞
