Hi. I´m new to fitbit and i´m trying to connect MFP to my fitbit. I went to apps and devices on my MFP app, and pressed "connect" to the fitbit tracker app. I then got redirected to a login site (in my safaribrowser) where i typed in my username and password for MFP, aswell as my email and password for fitbit. I then allowed MFP to gather information from my fitbit.
I thought everything went smoothly until i was asked to type in my username and password for MFP again. So i did, and was signed into the safaribrowser version of MFP, and my fitbit has not still been synced. I try again, and its just i vicious cycle! Please Help.
Allow me to help you @peterboe! Thanks for the explanation. You can go to your Fitbit Dashboard and check if your apps were successfully linked. Go to settings > click on applications > if you MFP then the procedure was properly done.
Addittionally, you may want this is what's gonna sync between Fitbit and MyFitnessPal.
Fitbit to MFP: steps, calories and Aria measurements. MFP to Fitbit: food and activities.
Keep me posted.
