01-01-2019 12:33
01-01-2019 12:33
I just downloaded Couch to 5k to my Fitbit today. When running, it kept stopping and I had to restart it multiple times and fast forward to where I left off. Is there a trick to this so that the app keeps running for the entire workout?
Also, can I integrate it with the existing C25K that I have been using for a few years to see progress?
Thanks.
Best Answer01-02-2019 08:14
01-02-2019 08:14
@Drjosie A warm welcome to our Community! Sorry to hear that your Couch to 5k isn't working as it should. Which phone are you using? Also which Fitbit device do you have? Try uninstalling the app, restart your device and reinstall it. For details on how the integration works please reach out to the developer. The same can be done about the C25K data, you will need to ask them what they allow to be exported (if anything is possible to export at all).
Let me know what they tell you.
