10-01-2019 19:37
10-01-2019 19:37
Is there any way to connect the heart rate from my Versa to the ismoothrun app so I can create custom run programs with intervals based on heart rate zones? That is the only app I’ve found with this functionality but I would prefer to not have to buy another heart rate monitor.
10-02-2019
11:13
14:54
10-02-2019
11:13
14:54
It's great to see you on the Community @CatZ150. I'll be happy to clarify your question.
The best way to find if this option is available would be to contact ismoothrun directly, because Fitbit has an open API. You can learn more about it by checking the Third Party Apps - FAQ.
10-02-2019 12:10
10-02-2019 12:10
I had also contacted ismoothrun and they responded quickly that it’s not possible because Fitbit uses proprietary software and protocols that are not Bluetooth standard. It might be time to start researching other devices.
Regards
10-03-2019
14:08
14:53
10-03-2019
14:08
14:53
Thanks for getting back @CatZ150. I appreciate that you mentioned you contacted ismoothrun.
If you would like to see this integration, you might want to post it in our Feature Suggestion board, those ideas are reviewed by our team and the status will change based in Fitbit's plans.
